Removing Door Panels
Old Jun 23, 2010 | 02:42 AM
HEMI_DAD's Avatar
My son pushed the switch and it broke. I will take some pics Thursday when a new switch arrives. NAPA will replace n/c as defective.
Dorman switch "Made in China"
Old Jul 2, 2010 | 06:31 PM
phondo2's Avatar
Hi All, I have a 2001 Monte Carlo SS and yesterday the driver side window fell off the track. We know we have to take to door panel off to get to it, but will these instructions to get to the speaker work? Thanks!
Old Jul 2, 2010 | 10:32 PM
yeah, its the same procedure.
Old Jul 8, 2010 | 07:27 PM
phondo2's Avatar
Smile Thanks!
Thanks! clips and screws no problem, have window jacked up with styrofoam now and panel back on until new window regulator arrives. Cables were all mauled. Always somethin! Recently had to have a new crank shaft sensor installed. Have a good weekend!
Old Jul 21, 2010 | 10:43 PM
norwex's Avatar
I was able to do the passenger side just fine replacing my 6.5's but when i did the drivers door i barely pried up on the window switch part and it snapped in half. now if i press the window buttons down too hard they fall in the door.
Old Mar 3, 2011 | 12:09 PM
Kzeppenfeld's Avatar
Default Picture Guide
Big thanks to Hemi_Dad for his instructional guide (I will repost his steps along with the pictures and excruciating details). I just took off my passenger side door and figured I should take some pictures for this thread (my first How To guide; have mercy). If necessary, feel free to stick this as a separate thing in the How To: 6th gen. I apologize for the quality, I only have a cellphone camera of poor quality..
Tools required: Phillips head screw driver, Torx T30 bit, patience.
Suggestions: Drop light (for light), mini flathead (for prying)
1) remove the phillips head screw behind the door handle.
2) remove the bezel: Pull up on the front part (by the power lock switch) and slide it out.
3) remove the door lock switch from the bezel: It has two 'clips' on either side. Pry (gently) on the sides of the housing until you can slide it out.
4) remove the phillips head screw behind the mirror
5) remove the two Torx screws by the handle on the door (T30 bit): They are set in at a slight angle.
6) remove the door panel: Start off by the mirror and gently start moving around the door. Don't yank on it, because you will break it. Just firmly and slowly slide your thumb around the door and the clips will pop out. If you go too hard you will break some of the ridges on the clips and will have a loose door panel. After the clips are all out, lift up on the panel to get it off of the hooks by the window.
The clips are these:
7) remove the window switch: Similar to the power lock switch, but at a more annoying angle.
To put it back on, just reverse everything. Goodluck!
Old Apr 23, 2011 | 12:51 AM
Vopartwork's Avatar
YouTube - 1AAuto Install Remove Door Panel Chevy Monte Carlo 2000-07
Here's A GOOD Video On Install/Remove Door Panels nice n simple
Old May 11, 2011 | 12:37 PM
MJClemm's Avatar
Default thanks...
thanks, Great video on how its done the right and easy way... Ive seen it done the HARD way before and I swore when it was done I thought it was a joke video it was that bad, Had to shut down the computer for showing me such horrible graphis...,This Video nailed it thanks a ton....MJC
Old May 16, 2011 | 07:45 PM
my00monte's Avatar
Anyone know how to remove the oval panels in the back seat? I'm talking about the ones under the rear windows, above the rear arm rest.
Thanks!
Tyler
Old May 20, 2011 | 10:32 PM
WreckedMonteCarlo's Avatar
If I could find the cord for my camera, I'd upload some pictures. We had to take my door panel to fix the tint on the window a few months ago, so I took pictures. The door panel is a pain in the butt to get back on though!
