Removing cover protecting steering column intermediate shaft & coupler
Old Oct 2, 2013 | 08:17 PM
charlie2's Avatar
Default Removing cover protecting steering column intermediate shaft & coupler
How did you remove the black plastic cover over the intermediate shaft and coupler from inside the vehicle, drivers side on a 96 Monte Carlo Z34? My goal is to disconnect the intermediate shaft from the stub shaft of the rack and pinion (steering gear). My repair manual and internet searches are not helping. I looked for clamps that might hold the plastic shroud in place but it does appear to have one so far. It seems like one cylindrical piece to me. Thanks for your answers.
Old Oct 3, 2013 | 08:25 PM
charlie2's Avatar
Solved. I found a hint that the pinch bolt location is outside of the car.
Use a long crowbar braced against the inner tie rod or stabilizer shaft to more easily lift the cover at its base. The cover is wrapped around a tube at its base.
Old Oct 4, 2013 | 01:12 PM
z34phantom's Avatar
Nice work!
MJClemm
Oct 29, 2012 06:14 PM
bk4256
Sep 30, 2009 08:36 PM
dhartenstein
Feb 19, 2007 08:06 PM
bk4256
Apr 3, 2006 11:20 AM
01blackmonte
Oct 17, 2005 07:30 PM
