Rear strut noise
Old Mar 19, 2011 | 02:10 PM
jimp00's Avatar
Default Rear strut noise
replaced the rear struts on the mc know have a knocking noise when driving,made sure all nut where tight put the mc on jack stands and put a jack under the wheel assembly jacked it up can hear noise could it be the spring.When I put the struts on new struts used original springs.
Old Mar 20, 2011 | 01:46 PM
Justin Knight's Avatar
One of the spring seat rubbers could be out of place, or I would tend to think a stabilizer link could be loose. Either the nut holding it to the strut or bar isn't tight enough. If you missed putting a rubber cushion in place that'll definatly do it.
Old Mar 20, 2011 | 02:50 PM
I hear worn Strut mounting brackets can cause a knocking sound....
Old Mar 20, 2011 | 05:11 PM
jimp00's Avatar
Going to take a look at it again.Thanks for help
ChibiBlackSheep
FWD Tech Guides '95-'07
114
Dec 12, 2015 08:19 PM
Budsjlm
Nov 26, 2012 08:00 AM
Love my Monte
Mar 7, 2012 07:16 PM
thumpingetocar06
Jan 2, 2010 11:30 PM
