rear end woes
Old Mar 25, 2012 | 03:23 PM
montehauler's Avatar
Default rear end woes
Anyone Know what kind of diff came in a 1985 Monte, I thought it was a 7.5 10 bolt, I bought a powertrax locker to go in it but it seems too small for the carrier, maybe a 7.6? it does have 26 spline axles.
Old Mar 25, 2012 | 05:48 PM
03SSLE's Avatar
GM used either a 7.5" or a 7.6" carrier in the Monte Carlo from '82 through '88. Since the 7.5" appears too small chances are you have the 7.6". That is unless the rear axle has been previously replaced. If that's the case you will need to ID it through the number stamped on the housing.
Old Mar 25, 2012 | 06:20 PM
No tag on diff, will take a closer look to see if I can find some identifying numbers.
thanks
Old Mar 26, 2012 | 09:16 AM
TheMonteMan's Avatar
i thought all 78-88 gbodies ran the 7.5" 10 bolt with exception of the olds 442, and the buick grand national that ran the 8.5" 10 bolt. the only difference was what series the carrier was depending on the gear ratio. ive never heard of a 7.6" rear. if you could post a pic of the housing.
Old Mar 26, 2012 | 10:18 AM
03SSLE's Avatar
One gear company I looked at showed both being used '82 through '88 but Richmond shows both being used all the way back to '78:
http://www.richmondgear.com/07pdfs/RG9.pdf
As long as the rear end hasn't been replaced I'm thinking he has the 7.6" since the 7.5" appears to be too small.
Old Apr 1, 2012 | 03:08 PM
Quick update, my car has the 7.62 diff. according to the guy at Richmond gear, thats what came in g body monte. I got the new parts for the 7.6 and they fit as he said. Now it's time to lay some =================!!!!!!!!!!!!!!!!!!!
rysZ34
Jan 21, 2012 07:33 PM
coreyeroc
Aug 31, 2009 05:19 PM
rgant_19
Feb 9, 2009 08:09 PM
rysZ34
Apr 9, 2008 07:17 PM
God_Bot
Jan 28, 2008 04:55 PM
