rear brake lock up! on 98 ls
Old 06-28-2008 | 10:37 AM
mikes03ss's Avatar
Default rear brake lock up! on 98 ls
if anybodyhas any suggestions on this matter iwould first like to say thank you for any input! heres the problem, when you first go to take off and apply the brakes, the rear wheelsgrab hard to the point that they will lock up and drag, have tried to bleedthe whole brake system, to no prevail ,drum is not wet from wheel cylinder leaking, i wasleaning towards front calipers, possible one frozen or sticking, if anyone has ever delt with this sort of thing, once again i'm very thankful for any input. oh andone more thing, after the first time theylock upand get going down the road all seems to be fine until you shut the car off and get back in it and go thru the process all over again. the last thing i want to do is have to take it to GMdealer , but if i have to i have to,
DerrtyD
04-26-2013 12:49 PM
Seabee
11-07-2012 11:48 AM
heartbeat
01-14-2012 11:47 PM
matrx10503
RWD Tech Guides '70-'88
12-29-2011 11:33 AM
yiranhu
11-22-2007 06:32 PM
