Radio on the ritz when rear defroster is on
Old Oct 18, 2009 | 07:39 PM
Absolutpolack's Avatar
Default Radio on the ritz when rear defroster is on
Exactly as the title says... Is this a common problem cause its definitely annoying, and with winter coming up that thing will be on alot more.
Old Oct 19, 2009 | 11:33 AM
RocknSS04's Avatar
That's an easy problem to diagnose. I had the same thing. There is a short in the grid on the rear window. Where is the question. Mine was under warranty. They replaced the window. Maybe someone else can help you trace it down. Has there been any repair done to it? Does all of the elements work on the rear defroster?
Old Oct 19, 2009 | 11:51 AM
Hmm, ill have to check it out. I dont know if the entire window defrosts, I've never noticed differently. I had just removed the On-Star antenna this summer by unscrewing it so I don't know if that could do it. First winter with the car so I don't know its history. Can I check the lines with a multimeter or are they somehow embedded?
MJClemm
Oct 9, 2022 09:13 AM
tj4ndirish
Jan 8, 2013 01:28 PM
rjmfa
Dec 22, 2012 12:17 AM
rogg5204
Dec 30, 2009 09:14 AM
01pacecar
Apr 29, 2006 12:38 PM
