Static through radio when I have the rear defroster on
Old Dec 14, 2009 | 07:47 PM
rogg5204's Avatar
Default Static through radio when I have the rear defroster on
I have a 2006 2LT and whenever I have the rear defroster on, the only thing I can get through the radio is static. As soon as I turn it off, the radio reception returns to normal. Is this normal for this to happen?
Old Dec 14, 2009 | 09:19 PM
well the antenna in these vehicles is in rear windshield, im not really sure if its common but it does kind of make sense that it would be static
(sorry dont mean to sound snotty lol)
Old Dec 14, 2009 | 09:34 PM
kweef's Avatar
check ur connections at the window to c if they r loose. there isnt a tsb for the 2006 but i believe 2000-04 have a tsb for it
Old Dec 14, 2009 | 11:00 PM
Dbl_D718's Avatar
Yeah the antenna is in the rear window, but you shouldn't get nothing but static with the defroster on. Like said, check your connections. How is the signal with the defroster off?
Old Dec 15, 2009 | 02:38 PM
rogg5204's Avatar
With the defroster off, reception is perfect. And yes, I know that the antenna is in the rear window. One of my friends leased a G6 that had the opposite thing as this happen to it; whenever he had the defroster on, reception got better. I will look for the connection though and check to see if it is loose.
Old Dec 20, 2009 | 12:16 AM
RocknSS04's Avatar
You have a short in the grid. Have them replace it if it's still under warranty. POS design.
Old Dec 20, 2009 | 08:26 PM
rogg5204's Avatar
Well, is this something that I can do for under $100, or should I just have the dealer look at it? It has to go in to the dealer anyways for the recall on the power steering lines. I was thinking about having them look at it then or just asking the guys at the parts counter. The parts counter guys were really helpful when I was trying to find out what was causing the p0455 code to be thrown out. They basically gave me the printout with exploded views and what goes wrong most often with the vehicles they have seen with that code. Instead of paying $300 for labor plus the $35 part I only had to pay for the part and it only took 5mins to install.
Old Dec 24, 2009 | 06:56 AM
RocknSS04's Avatar
Can you share with us what the part was that you replace to cure the P0455 code?
Old Dec 26, 2009 | 05:22 PM
mak330's Avatar
lol ya i have the same problem, im hoping if i get an aftermarket deck it will come in better. i thought i read in another post there is an "antenna booster" you can install. they had a 6th gen though, its probly the same.
Old Dec 30, 2009 | 09:14 AM
rogg5204's Avatar
This is kind of off topic, but the part that I replaced for the p0455 code was the charcoal canister and evap solenoid unit. I have a whole thread on this, in the general tech area, I think. Just do a search for p0455. When my car goes in for the recall on the power steering lines, I am going to ask them about the static when the defroster is on.
MJClemm
Oct 9, 2022 09:13 AM
maxxpro123
Nov 13, 2014 07:59 PM
J-Bob
Apr 8, 2010 08:46 PM
Absolutpolack
Oct 19, 2009 11:51 AM
Aaron_Provost
Apr 29, 2008 07:15 PM
