No power steering, need help!!
Old Jan 23, 2007 | 04:12 AM
NRDMonte's Avatar
Default No power steering, need help!!
I have a 2000 Monte Carlo LS with only 39,000 miles on it. The other day I backed out of my driveway and then tried to go foward and I had no power steering. It has fluid, its not leaking, and the belts are good. Can anyone help???
Old Jan 23, 2007 | 04:29 AM
kodasdad23ls's Avatar
Default RE: No power steering, need help!!
was this only one time or has it never came back? My previous car had a problem with the power steering intermittently not working but only when the fluid was cold, the rack and pinion ( more specifically the rack )was the prob.
Old Jan 23, 2007 | 04:37 AM
NRDMonte's Avatar
That was Saturday night and I still have no power steering. It does it cold or warm. I had a couple people say it could be power steering is bad or the rack and pinion.
Old Jan 23, 2007 | 04:38 AM
NRDMonte's Avatar
Sorry power steering pump could be bad.
Old Jan 23, 2007 | 06:29 AM
mickey's Avatar
check the pump or rack. with that low of millege on it i would think tha tit is most likely the pump screwing up. racks are normally good longer then this. \
but you can take it to a alliment shop also and they should be abel to tell you if it is the rack or not.
Old Jan 23, 2007 | 06:45 AM
NRDMonte's Avatar
Thank you I will try that.
kingreyna
Jan 4, 2015 11:53 PM
TomF106SS
Oct 6, 2014 10:13 AM
Clueless
Dec 16, 2010 01:29 PM
livinlow
Mar 22, 2007 08:52 PM
