7th Gen ('06-'07): Radiator drain cock location
Old Aug 27, 2022 | 11:58 PM
5.3MonteSS's Avatar
Default Radiator drain **** location
Hi all!
I just bought an 07 SS and I'm trying to do a coolant flush but I can't find the damn radiator drain ****. Usually they're on the driver side of the rad facing the engine, but I just don't see it.
I searched the forums, but didn't seen any 5.3 SS coolant flush info. Thank you in advance!
Old Aug 28, 2022 | 05:38 PM
Personally, I wouldnt touch it even if you do find it. Id be worried its never been opened, and given the age of the car that either the plastic would break or the seal wouldn't hold after closing.
I'd just slice the lower radiator hose (and replace it of course) - assuming it looks original and has never been off either.
Old Feb 26, 2023 | 11:10 PM
Thiggins98's Avatar
Default Question
Originally Posted by 5.3MonteSS
Hi all!
I am about to do the same thing on my 07 SS I was wondering what you ended up doing? Did you end up cutting the hose??
Old Mar 21, 2023 | 03:57 AM
jthorpe's Avatar
I'd try to remove the clamp on the lower radiator hose and pull the hose off instead of cutting it off. Unless it's really mushy feeling (flimsy, etc.) then you don't need to replace it.
straffin
Dec 30, 2017 09:59 AM
chevyrider08
Dec 15, 2016 08:12 PM
rjo98
May 9, 2013 06:39 AM
DRuben
May 6, 2011 08:24 PM
zipsayain
Feb 25, 2007 02:23 AM
