Question about 2005 DRL pin bypass
Old Oct 18, 2010 | 04:43 AM
DuttonSS05's Avatar
Default Question about 2005 DRL pin bypass
Hate to make a new thread about this but I didn't know who best to PM about it. What I wanted to make sure was this: After bending pin 87 the DRLs no longer function BUT my low-beams will turn on as it gets dark, correct?
Reason I ask is I'm about to invest in some HIDs, and don't want to burn them out during the day but still having the ALC on makes things easier. Thanks for any help!
Old Oct 27, 2010 | 02:52 PM
05MonteLS's Avatar
Default DRL for 05 Monte Carlo
Yes, the Low Beams will turn on still because they rely on the light sensor that's next to the defroster duct. I've never installed HID's before, but I do know that my DRLs were disabled after I pulled the DRL relay. The SEL light never turned on nor did any warning messages show up in the Info. Center. I didn't even have to pull any wires or bend any pins. My low beams still turn on at night too. I think this only applies to 2005 Montes though.. You should be fine.
Old Oct 27, 2010 | 06:45 PM
Paul1965's Avatar
The low beams will work fine, but a word of advice if you have a garage: disable the auto on feature of the headlights too. Otherwise your lights will be on as soon as you start the car, then shut off when you back out of the garage. They say that will reduce the life of the HID's. The BCM can't be programmed to disable them, so I bypassed the headlights all together and have it turn only my park lights on.
Old Oct 28, 2010 | 01:53 PM
DuttonSS05's Avatar
No garage so don't have to worry about that one.
Jkozy
Jul 3, 2019 07:01 PM
Dawg
Aug 22, 2016 11:36 AM
mr. roboto
Jan 12, 2015 05:54 AM
M.C.BOB
Aug 1, 2012 01:46 PM
DuttonSS05
Oct 21, 2010 08:21 PM
