Pulsing when braking... (2001 3.8L)
Old Mar 28, 2008 | 03:27 PM
Fusiform's Avatar
Default Pulsing when braking... (2001 3.8L)
Hey,
So I have a 2001 Monte SS. Whenever I brake I get what feels like a pulsing coming from my brake pedal. I have already replaced the front rotors and pads along with the intermediate steering shaft and the problem is worse then ever. During slow braking you can really tell that what ever is making the noise/pressure is rotating. Every revolution it feels something is grabbing. At high speeds it is much worse then lower speeds. My mechanic has basically told me they haveno more ideas for the problem. If anyone hasinformation about this please fill me in or offer your opinion. Thank you
Old Mar 28, 2008 | 04:07 PM
2000_BLACK_SS's Avatar
Default RE: Pulsing when braking... (2001 3.8L)
i am not sure but it could be a wheel bearing maybe.
Old Mar 28, 2008 | 04:51 PM
rysZ34's Avatar
Check to see if your calipers are sticking.
Old Mar 28, 2008 | 07:02 PM
montecarlomike81's Avatar
I would check the rear brake rotors and calipers.
Old Mar 28, 2008 | 09:12 PM
chuckd 06 ss's Avatar
It's your rear rotors
Old Mar 29, 2008 | 09:27 AM
Fusiform's Avatar
I do believe it is my rear rotors. When I was thinking about it after I posted I went through everything I was feeling and realized when I brake and take my hands off the wheel it still tracks perfectly which would make sense that it is the rear and not the front rotors.
Old Mar 30, 2008 | 08:53 AM
RocknSS04's Avatar
Sounds like you have corrosion or dirt behind the rotors. They might be warped now. Take the rear wheels, calipers, and rotors off the car. Clean ALL the mating surfaces good. Turn the rotors. It can only help. Re-install everything. Here's the key: HAND TORQUE ALL the lug nuts tight to 100 ft/lbs in a staggered pattern. DO NOT USE AN IMPACT WRENCH, NOR LET ANY TECH USE ONE. HAND TORQUE ONLY! The next thing you need to do is to check them again after 30-50 miles. They WILL loosen.
Mis-mounting has ALWAYS been my biggest thorn in wheel vibration and pulsing brakes. It WILL warp rotors.
Old Mar 31, 2008 | 12:35 PM
Fusiform's Avatar
I replaced the rear rotors and pads yesturday and the problem is fixed. Its weird driving now, when I break I expect it to bump and pulse and its just smooth stopping... I'm sure I willget used to it though. thanks for the help.
Old Apr 1, 2008 | 08:46 PM
RocknSS04's Avatar
Go and double check the torque of the lug nuts. REMEMBER: improper tightening of the lug nuts is the MAIN cause of warping rotors.
100 ft/lbs.
MonteCarloSS02
Aug 18, 2014 08:22 AM
ExplosiveSoundz
Mar 30, 2008 02:41 AM
boakesb
Jun 19, 2007 03:29 PM
White05LT
Dec 16, 2006 09:54 PM
Phos187
Oct 2, 2006 10:37 PM
