PROGRAMMING a FOB for a sixth gen,.....
Old Mar 18, 2012 | 11:40 AM
MJClemm's Avatar
Default PROGRAMMING a FOB for a sixth gen,.....
Hello, does anyone know if you can program a FOB for the sixth gen without a factory radio? I need the info bad....thanks. Mjc
I need this info Bad please help me.. Thanks..Mjc..
Old Mar 18, 2012 | 12:14 PM
Do you have an old one? just switch the internals around, i'm assuming if you just got a new one you got it for the better buttons, that's what i did and just swapped the internals.
otherwise without the stock radio, you have to take it to a dealership
Old Mar 18, 2012 | 12:16 PM
One Dark SS's Avatar
You can, i've done it when i bought the car 4.5 years ago... just follow the prompt through the radio (access it the same way you would to reset the oil monitoring)
Old Mar 18, 2012 | 12:19 PM
Old Mar 18, 2012 | 12:21 PM
The stock radio or the dealership are your only options. If you have the stock radio laying around just hook it back up.
Old Mar 21, 2012 | 01:12 PM
MJClemm's Avatar
Default Ok.. Thanks
Ok.. Thanks guys.. To the dealership to waste money I go.. Was just hoping there was ..... But just stinks that a simple radio can screw up so many issues.. A radio....lol.. I could understand changeling the PCM, but not the stupid radio... What a stupid design...lol... Thanks... Mjc....
Old Mar 21, 2012 | 02:25 PM
Do you have the original key fob? stop by and I'll swap them for you, or you can do it, just swap the case and the buttons
Old Mar 21, 2012 | 02:29 PM
Buy a harness that you could relocate the stock radio with, and then tuck the wires away and only hook up your radio as you need its functions.
Old Mar 24, 2012 | 07:07 PM
my bad, totally missed the without part...
Old Mar 27, 2012 | 01:45 AM
Jaythepunk's Avatar
I'm a locksmith and I wasn't able to program the remote with my Key Programmer either. I had to go to the Junk Yard and get a stock radio and have it unlocked to program my remote. I also invented a trick to repair the remote if the battery tray has became un-soldered from the board. A soldering iron can get too hot and damage the internals but this way seems to be flawless if anyone wants to know, I'll explain it.
Furder2010
Oct 22, 2017 06:49 PM
ttmillus2
Jul 5, 2011 10:28 AM
Theflash2515
Aug 13, 2010 03:40 PM
Ethan
Aug 11, 2010 11:36 PM
mekoku
Mar 11, 2010 05:48 PM
