Problems at the gas pump ????
2006 SS
Yeah.
I pump gas, and the nozzle clicks off wayyy too sensitively sometimes. Sometimes its fine, but others i have to find the perfect position, and hold the handle in just enough.
Is this normal? Is there a problem? Or did I just forget how to pump gas?
Yeah.
it is normal, does the same thing on my car also! also when I try to get it totally full it usually shuts off and never restarts for me! I have never even came close to getting a full tank of gas in my car....
It does not happen all the time for me, because I think I pretty much figured out exactly how to wiggle the pump, and exactly how to get the rubber cup thing on the end of the pump to go into my car. But on occasion it still happens to me too. But I always get a full tank out of it.
But I totally understand how annoying it is, because its done it to me several times.
Move to NJ. They don't let us pump our own gas here, and we still have some of the cheapest gas in the country. Typically this is related to the nozzle on the pump and not the fuel inlet itself, but it sounds like this is too common for that explanation. Are these the spill proof nozzles with the big spring seals that you have to really push down into the inlet before they will work (very common in NY)? Those things are a nightmare to pump with, and are the only type I consistently have issues with, and thats in any car.
ladybridgeport
May 29, 2020 08:20 AM
z34phoenix
Jan 4, 2012 04:05 PM
