7th Gen ('06-'07): problem removing ignition coil assembly
Old Jun 21, 2018 | 08:57 AM
bricknermc06's Avatar
Default problem removing ignition coil assembly
Hello -
Has anyone removed the ignition coil assembly without removing the intake manifold? The bolt closest to the alternator seems to be completely inaccessible unless there is a special tool involved in the process.
Any advice is greatly appreciated.
File Type: jpg
File Type: jpg
Old Jun 28, 2018 | 09:34 PM
Monte#3's Avatar
I am confused my coil assembly doesn't look like that? I can't see much from your pictures maybe if you had some zoomed out also. Is that the V8? I wish I could be of more help... hopefully someone else replies soon. I would suggest to buy whatever tool you need as its always cheaper than paying for service. I would say J tool... did you resolve this?
Mr.Monte
Jan 28, 2012 05:14 PM
kody02ss
Dec 12, 2011 12:09 AM
options13
Nov 2, 2011 12:46 PM
pcarey
Feb 20, 2011 09:12 AM
dickie34
Jul 6, 2007 12:08 AM
