Problem with PRND readout
Old Mar 20, 2012 | 11:07 AM
saigashooter's Avatar
Default Problem with PRND readout
Hi all,
the digital display that shows the gear selection and odometer info in my 6th gen has gone out.
Does anyone know if it is possible to replace just this section of the gauge cluster, and if doing so will necessitate having the odometer mileage programmed by a shop or dealer?
Old Mar 27, 2012 | 01:54 AM
Jaythepunk's Avatar
You could try a junkyard cluster but the mileage is going to be different. open it up and see if there is a bulb behind it that may have burned out. I know on the older ford radios that was really common.
Justin Myers
Sep 19, 2012 08:23 PM
inyanalili
Apr 2, 2012 08:31 AM
