Problem with heater in 05 LT
Old Jan 3, 2011 | 07:42 AM
saigashooter's Avatar
Default Problem with heater in 05 LT
so my heat has decided to stop working, I noticed it was taking longer than normal to get warm while driving the other day, and it never did get warm over my 80 mile journey.
Here is what I observed
Temperature gauge, slowly gets up to 175 and never went higher (it was 4 degrees F outside)
No sloshing water sound from the cooling system
Setting the heat to cold worked fine, and it was ice cold
Changing the settings on the vents from feet/hands to feet only or hands only did work
The blower seems to be dying (again, it did that a year ago), and the upper speeds aren't as fast as they used to be.
Where should I start looking to troubleshoot this?
Old Jan 12, 2011 | 05:56 PM
farmerjg's Avatar
Have you tried changing your thermostat? I had an older car with a bad thermostat, car wouldn't heat up, I changed the thermostat then the heat got hot. $15 for a thermostat and gasket, probably worth a shot.
Fan speeds....is the blower motor resistor what went out last time? Sounds like it could maybe be that.
Old Jan 27, 2011 | 09:00 PM
DeadboxDave's Avatar
Just finished replacing my blower motor for the second time in the last year. It did the same as what youre going thru both times for me. I changed the resistor block and the climate control panel THEN the blower motor. Turned out I could have saved the cash by going directly after the blower motor.
Good Luck
Dave
Old Jan 27, 2011 | 09:04 PM
sounds like your thermostat is stuck open
twk114
Dec 29, 2011 01:12 AM
racecarkid
Oct 23, 2010 07:36 PM
jeffsmonte
Jul 19, 2010 08:04 PM
Rich
Apr 12, 2010 12:15 PM
js2000mc
Oct 31, 2008 10:37 AM
