1997 Monte Carlo Z34 Idling Problem
Old Feb 26, 2010 | 08:16 PM
bwill987's Avatar
Default 1997 Monte Carlo Z34 Idling Problem
Hey everyone,
I'm having a pretty serious idle problem with my 1997 Monte Carlo Z34.
The problem i'm having is when i start my car up, regardless of the temperature, the rpms shoot up to 3 or 4000 and slowly come back down to around 900. This also only happens if i give it some gas while starting up.
If i dont press my acceleration pedal while starting the car up, it will eventually turn on, but the rpms will drop right back down to 0 and the car will turn right off.
The really aggrivating problem is when the car is stopped at a traffic light or stop sign, or when coasting under 20mph without accelerating, the power steering turns off and the engine shuts down, causing me to have to come to a stop and restart the engine, starting the cycle all over again.
I have replaced my MassAirFlow sensor, my ThrottlePositionSensor, cleaned out the throttle body, and repaired a leak in the connector that connects my FuelPressureRegulator hose to my throttle body. Each of these replacements seemed to work or correct the problem for about a day, but the problems would start right back up again the next.
The codes that i got when having the diagnostic tool hooked up were
P0121 Throttle/Pedal Position Sensor/Switch Circuit Range/Performance and and P0441 Evaporative Emission System Incorrect Purge Flow.
The next part i was advised to check/replace is my Idle Air Control Valve. I have to drive back to MD from SC, about an 8 hour drive, next week, and really need to get my car in shape by then. Any comments or suggestions about what to do next? I would greatly appriciate it.
Gotta love them monte carlos...!
Old Feb 26, 2010 | 08:27 PM
mak330's Avatar
idk man it sounds like a severe misfire, or vacum leak. the only problem i ever had with the lumina was with the egr. seems like others are having the same problem.
i know i hate when i have to fix my car but it happens. theres another thread on the same subject, with about 100 diferent responses. i would take it to a mechanic and bite the 25-50 bullet. its probly a small filter or sensor.
i dont get electronic engines, all they do is break b4 they diagnose the problem.
zlbh08
Jan 27, 2013 10:32 PM
Crazy4408pac
13
Aug 5, 2012 05:53 PM
ohmonty26
Sep 30, 2010 09:08 AM
connersdad19
May 29, 2009 03:24 AM
Z34 in the Couve
Jan 28, 2009 03:18 PM
