power mirror wiring
Old Mar 12, 2007 | 07:23 PM
bilms01's Avatar
Default power mirror wiring
Does anyone have a wiring diagram for the power mirror switch from a 96 M/C?
Just need to ID the wires on the switch.
Old Mar 13, 2007 | 04:35 AM
enibum's Avatar
Default RE: power mirror wiring
I don't have a diagram, but you can use a volt meter to determine which are which. Just check from ground to each terminal at the switch. The terminal that has twelve volts on it is the one that leads back to the battery. The other goes to the mirror. Be sure to have your ignition turned on so that power can be supplied to the switch. Hope this helps.
robknight13607
Nov 20, 2016 01:24 PM
seanvirgin
Aug 18, 2013 09:08 AM
Vladimir
Nov 26, 2011 11:41 PM
cain45
May 22, 2007 12:34 PM
kevin187
Dec 12, 2004 12:18 AM
