power mirror wiring
Does anyone have a wiring diagram for the power mirror switch from a 96 M/C?
Just need to ID the wires on the switch. |
RE: power mirror wiring
I don't have a diagram, but you can use a volt meter to determine which are which. Just check from ground to each terminal at the switch. The terminal that has twelve volts on it is the one that leads back to the battery. The other goes to the mirror. Be sure to have your ignition turned on so that power can be supplied to the switch. Hope this helps.
