power mirror 06 mc
Need help with figuring out why my power mirrors aren't working properly. The driver side mirror only goes up and down. The passenger side mirror only goes left to right. Checked connections and fuses - OK. Switch looks ok also. Don't have a wiring diagram to look at. If anyone can help will be greatly appreciated. Thank You
P o w e r Mirrors'"'«"~''*^^''"«
If t h e p o w e r m i r r o r s y s t e m f u s e i s o p e n a n d a s h o r t t o g r o u n d i n t h e
b a t t e r y p o s i t i v e v o l t a g e circuit i s n o t d e t e c t e d , t h e f a u l t c o u l d b e a s h o r t t o g r o u n d i n o n e o f t h e
p o w e r m i r r o r c o n t r o l c i r c u i t s . T h i s w o u l d o p e n t h e p o w e r m i r r o r s y s t e m f u s e w h e n t h e m i r r or
s w i t c h i s p r e s s e d .
If b o t h p o w e r m i r r o r s a r e i n o p e r a t i v e o n o n e o r m o r e a x i s , t h e m o s t p r o b a b l e c a u s e i s a p o w e r
m i r r o r s w i t c h f a i l u r e . H o w e v e r t h e f a u l t c o u l d b e a n o p e n circuit o n t w o o r m o r e o f t h e p o w er
m i r r o r c o n t r o l c i r c u i t s.
T h e p o w e r m i r r o r a s s e m b l y i s e q u i p p e d w i t h a pigtail h a r n e s s a n d i s n o t s e r v i c e a b l e . If a n
i n t e r n a l o p e n o r s h o r t i s d e t e c t e d i n t h e p o w e r m i r r o r a s s e m b l y , r e p l a c e t h e p o w e r m i r r or
a s s e m b l y .
I n s p e c t f o r a f t e r m a r k e t d e v i c e s w h i c h c o u l d a f f e c t t h e o p e r a t i o n o f t h e s y s t e m . I n s p e c t t h e e a s i ly
a c c e s s i b l e o r v i s i b l e s y s t e m c o m p o n e n t s f o r o b v i o u s d a m a g e o r c o n d i t i o n s w h i c h c o u l d c a u se
t h e s y m p t o m . F a u l t y e l e c t r i c a l c o n n e c t i o n s o r w i r i n g m a y b e t h e c a u s e o f i n t e m n i t t e n t c o n d i t i o n s.
R e m o v a l & I n s t a l l a t i o n
C A U T I O N
A p p r o v e d s a f e t y g l a s s e s a n d g l o v e s s h o u l d b e w o r n w h e n p e r f o r m i n g t h i s p r o c e d u r e t o r e d u ce
t h e c h a n c e o f p e r s o n a l injury.
M o t o r
1 . R e m o v e t h e f r o n t d o o r t r i m p a n e l .
2 . If n e c e s s a r y , d i s c o n n e c t t h e e l e c t r i c a l c o n n e c t o r t o t h e m i r r o r w i r e h a r n e s s .
lofS 8/18/2013 10:01 AM
2007 Chevrolet Monte Carlo 3.5L Flex Fuel 6cyl | Repair Guides | Exte... AutoZone.com | Page Not Found...
3. R e m o v e t h e m i r r o r f r o m t h e f r o n t d o o r.
4 . R e m o v e t h e m i r r o r f a c e.
5. R e m o v e t h e m i r r o r m o t o r s c r e w s.
6 . R e m o v e t h e m i r r o r m o t o r e l e c t r i c a l h a r n e s s t h r o u g h t h e m i r r o r h o u s i n g.
7. R e m o v e t h e m i r r o r m o t o r f r o m t h e m i r r o r h o u s i n g.
8. T o i n s t a l l , r e v e r s e r e m o v a l p r o c e d u r e.
D i s c o n n e c t t h e p o w e r w i n d o w s w i t c h w h e n w o r k i n g i n s i d e t h e d r i v e r d o o r . W h e n o p e r a t e d , t he
E x p r e s s U p / D o w n F e a t u r e a l l o w s t h e d o o r w i n d o w t o m o v e v e r y q u i c k l y , w i t h o u t s t o p p i n g , w h i ch
c o u l d c a u s e p e r s o n a l injury.
N O T E
A p p l y p r o t e c t i v e c o a t i n g / t a p e at t h e i n s e r t i o n p o i n t o f t h e s m a l l f l a t - b l a d e d t o o l in o r d e r to
p r e v e n t d a m a g e t o t h e i n n e r d o o r t r i m p a n e l.
C A U T I O N
W h e n r e m o v i n g a d o o r t r i m p a n e l o r s w i t c h p l a t e , t h e i g n i t i o n s w i t c h m u s t b e i n t h e O F F
p o s i t i o n . T h i s w i l l e l i m i n a t e t h e p o s s i b i l i t y o f s h o r t i n g o u t t h e s w i t c h if a s c r e w d r i v e r , a w l o r m e t a l
o b j e c t is u s e d t o r e m o v e t h e s w i t c h f r o m t h e h a r n e s s.
1 . I n s e r t a p l a s t i c f l a t - b l a d e d t o o l a t t h e f r o n t e d g e o f t h e s w i t c h m o u n t i n g p l a t e . P r e s s t he
t o o l r e a r w a r d t o r e l e a s e t h e m o u n t i n g p l a t e r e t a i n e r a n d lift u p o n t h e f r o n t o f t h e p l a t e.
2 . U s i n g a s m a l l f l a t - b l a d e d t o o l , c a r e f u l l y r e l e a s e t h e m i r r o r s w i t c h r e t a i n e r s a n d r e m o v e t he
S w i t c h
C A U T I O N
s w i t c h .
3. D i s c o n n e c t t h e e l e c t r i c a l c o n n e c t o r f r o m t h e s w i t c h.
4 . R e m o v e t h e s w i t c h f r o m t h e door.
5. T o i n s t a l l , r e v e r s e r e m o v a l p r o c e d u r e.
a s s e m b l y .
C A U T I O N
M o t o r
N O T E
C A U T I O N
S w i t c h
C A U T I O N
s w i t c h .
