possibe battery draw
Old Dec 8, 2014 | 06:00 PM
avendo's Avatar
Default possibe battery draw
I charged the batt a few days ago and battery acid meter shows real good,i went to start the car today and battery showed low voltage on my radar detector...how much is to much? the computer must take a little bit?
Old Dec 8, 2014 | 06:09 PM
What type of Battery do you have ? How old ? Have you make sure your cables are tight ? What range is you amp gauge indicating ?
Please post as much infor as you can to help member's help you!
Good Luck
Battery Basics: A Layman's Guide to Batteries
For Member's like me
Battery Basics: A Layman's Guide to Batte | BatteryStuff Articles
Old Dec 9, 2014 | 05:51 AM
avendo's Avatar
Its an interstate batt, maybe 2 yrs old .. Will do a load test on it, i grew up in a car dealership.. All fords.. Lol i own all chevys
Old Dec 9, 2014 | 05:54 AM
avendo's Avatar
my car does not have an amp guage...
Old Dec 9, 2014 | 06:41 AM
Dear `Santa,
Please get member `Avendo a amp gauge 4 Christmas `if U can >
Poor kid had to grow `up in a Ford Dealership You know how harmful that can `be (lol)...
`Avendo, I hope that one of our expert tech member's can help you with your
mystery battery reflected `drain >Good Luck<
Old Dec 9, 2014 | 07:11 AM
How old is the battery?
Generally they have a 3 to 5 yr life span...
It could have what they call a dead charge,
Acid may read fine but the plates inside is what wear out..
I would also have your alternator checked.. It may also have a diode that may be worn/wearing out..
You could get the battery load tested... But I don't trust the new "computerized" load tester..
I prefer the old style ones for a true reading.
I had one tested at Advance auto that said it was good.. However, My friend still has an old school one that said it was definitely dead with a dead charge on it!
So, It could be both the battery and the alternator is worn/wearing out.
Old Dec 9, 2014 | 03:20 PM
avendo's Avatar
Ok it charges at 14.5 volts and I have like 4 load testers and it shows weak,right on the edge of good on the tester,dead charge could be....
Old Dec 10, 2014 | 07:18 AM
avendo's Avatar
Charged it enough i guess... Buy new battery? .. Sure do miss the 39 dollar batterys...
kkritislas
Aug 30, 2014 05:33 PM
ladybridgeport
Mar 22, 2012 01:05 AM
ladybridgeport
Apr 28, 2011 08:23 PM
craig229
Mar 6, 2010 12:49 AM
Yellow_Monte
Jul 19, 2007 05:54 PM
