Popping Sound
Old Jan 13, 2012 | 12:07 PM
Mr Grizzly Mint's Avatar
Default Popping Sound
When I am going slow and accelerate or decelerate i hear a popping sound. Kind of like when a kernel of popcorn pops only louder. Sometimes one pop sometimes multiple in a row. I cant pinpoint where it is coming from. Almost sounds under me and to the right. Now what is it Suspension, engine bracket, or is my 6'5" 315lbs *ss breaking the seat?
Old Jan 13, 2012 | 12:10 PM
Might be a strut mount, they pop sometimes when they get old & wore, how many miles you got?
Old Jan 13, 2012 | 01:28 PM
only got 68k miles
Old Jan 13, 2012 | 08:35 PM
Old Jan 16, 2012 | 09:13 PM
mwjames's Avatar
Your engine seems to be running fine? Not a horrible backfire?
Old Jan 16, 2012 | 09:37 PM
strut mount or somewhere around there. mine does the same thing, plenty of bushings that can go bad, since these cars are getting pretty old, i would check all the bushings.
Old Jan 21, 2012 | 12:24 PM
Justin Knight's Avatar
It's called the intermediate steering shaft and it's an annoyance only. The collapsible section of the steering column is a common clunker in most gm's. If it really bugs you buy a new one, ask a machinist to drill a hole and thread it for a grease fitting. Put it into the car and grease it with a thick poly synthetic grease every oil change and it won't clunk again. We do it at my shop often and mostly to pickup trucks. If you really wanted to you can just have it done to the original but you would need to grease it more frequently because it's already wore a small amount.
Old Jan 24, 2012 | 02:06 PM
One Dark SS's Avatar
i was told by one mechanic that it was that inter. shaft... wasn't satisfied with that so i went else where.. took them 3hours to figure it out.. turns out one of the bolts on my steering rack was just lose enough to allow it to wiggle under hard acceleration and when hitting a hard bump. Charged me for 1/2h .
But like trewny said.. tons of bushings that could be causing that. Good luck!
iMuf
Jan 15, 2014 09:07 PM
nighthawk626
Oct 18, 2010 09:48 PM
Muddauber
Nov 17, 2009 12:53 PM
thewhitestcarlouknow
Oct 16, 2007 09:49 PM
ratbrat1234
Apr 28, 2006 09:08 PM
