PO128 Code
Old Apr 23, 2011 | 12:09 PM
bambi88's Avatar
Default PO128 Code
My fiance and I replaced the water pump and put a 180* thermostat in and my check engine light came on with this PO128 code? Anyone know what it is?
Old Apr 23, 2011 | 12:31 PM
You should check coolant level, Bleed air out ..
A code P0128 may mean that one or more of the following has happened:
1)Low engine coolant level
2) Leaking or stuck open thermostat Faulty cooling fan (running too much
3) Faulty coolant temperature (ECT) sensor
4)Faulty intake air temperature (IAT) sensor
Old Apr 23, 2011 | 12:49 PM
bambi88's Avatar
Is it because of the 180* thermostat?
Old Apr 23, 2011 | 04:23 PM
zipper's Avatar
Have you had your PCM tuned to accept a 180* tstat? If not, I would put money on that being the problem. IIRC stock tstats are 195*.
Old Apr 23, 2011 | 04:33 PM
bambi88's Avatar
No, I havent had it tuned to accept a 180* tstat. I want get the ZZP 1.0 PCM anyway, so I'll just save up for that to be my next mod
yfz450man
Jul 24, 2011 02:21 AM
Sporty7579
Jun 26, 2009 06:22 PM
cj702
Aug 28, 2005 12:50 PM
chorales
Jul 24, 2005 05:33 PM
king2805
Jul 14, 2005 10:34 AM
