PO128 Code
My fiance and I replaced the water pump and put a 180* thermostat in and my check engine light came on with this PO128 code? Anyone know what it is?
You should check coolant level, Bleed air out ..
A code P0128 may mean that one or more of the following has happened: 1)Low engine coolant level 2) Leaking or stuck open thermostat Faulty cooling fan (running too much 3) Faulty coolant temperature (ECT) sensor 4)Faulty intake air temperature (IAT) sensor |
Is it because of the 180* thermostat?
Originally Posted by bambi88
(Post 318524)
No, I havent had it tuned to accept a 180* tstat. I want get the ZZP 1.0 PCM anyway, so I'll just save up for that to be my next mod :)
