6th Gen ('00-'05): Plugged Cat after doing a lower intake
Old Jun 9, 2014 | 06:39 PM
svzpt71's Avatar
Unhappy Plugged Cat after doing a lower intake
i am stumped as to why after doing a Lower intake gasket and upper plenum that now my exhaust is plugged and my cat gets cherry red hot. any thoughts or suggestions?
Old Jun 9, 2014 | 08:17 PM
Knock too much carbon loose?
Maybe just a coincidence
Old Jun 9, 2014 | 08:36 PM
turbo monte's Avatar
To much coolant blew through exhaust before the repair was done to clog the cat is my guess.
Old Jun 10, 2014 | 03:48 AM
svzpt71's Avatar
I was very careful doing the work, I cleaned the intake and throttle body off the car. There was no white smoke indicating a burning coolant condition... just a strong sulfer odor about a min or two after startup... I didn't rev the motor at start either, I let it naturally catch up with the idle and run for a few min to warmup to burp the cooling system then as I checked my gauges I smelled the odor in the car and faint smoke coming up from the console area... then the check engine light came on followed by a backfire after massaging the throttle, I shut it down and looked under the car and I seen a cherry red cat... that's all the details I got.... now last week I had the tranny done for a P1811 update kit however the car ran flawless prior to the intake job I did.
Cruvolo93
Nov 22, 2014 09:26 PM
2000 Monte
Sep 1, 2014 02:31 PM
monte07
Feb 15, 2011 07:35 AM
Rugermk2
Apr 7, 2010 08:05 PM
RosDaddy
Feb 11, 2010 02:33 AM
