View Poll Results: Do you have this plug that is not plugged into anything?
Yes
57.14%
No
42.86%
Voters: 7. You may not vote on this poll
Plug to nowhere?!
Old May 26, 2010 | 10:02 AM
  #41
kweef's Avatar
that is a control valve for your egr
egr and air injection systems are not the same
EGR-exhaust gas recirculation is a system that takes exhaust gases and puts it back into the cylinders. this reduces the amount of fuel/air needed to fill the cylinder before the compression stroke. the reduced amount of fuel/air in the cylinder reduces the controlled burn temp in the cylinder reducing the level of NOx in the gases.
Secondary Air Injection- injects outside air into the exhaust before the catalyst to increase the catalysts efficiency reducing emissions.
Old May 26, 2010 | 11:05 AM
  #42
MAMONTE's Avatar
Ok, i'm way late on this tread, but you are not the first person to ask about that plug!?
I checked my mom's 2000 Bonneville a few months back for another member...It DOES have the plug, and it is plug in right where the rear of the engine cover hooks on. There is a connector on that thing that the plug goes into. We came to the conclusion that it was a feature on the Bonneville, not on the Monte, and was supposed to be not used on the Monte. Because his Monte, like your Monte, did not have the connector like the Bonneville.
Well I see a member with a 2000 has the same connector, and its plugged in??? It must be some feature of some sort that not all 3800's have.
Old May 26, 2010 | 02:16 PM
  #43
Pure2sin's Avatar
Yeah I am just wondering-What is the feature? Not that it is going to increase performance or anything but I just wanted to know what it was.
Old May 26, 2010 | 09:09 PM
  #44
lucian*91's Avatar
the tube on the right wraps around the engine and goes under somewhere though. i dont see it connecting back into the intake
Old Jun 7, 2010 | 11:24 AM
  #45
It's a plug for a secondary air pump, which is part of a special emissions package (most likely for CA) that most cars just do not have.
/thread
Old Jun 8, 2010 | 03:37 PM
  #46
Pure2sin's Avatar
Yeah that MUST be it. I noticed the Relay and nothing is there. Makes sense.
Cowboy6622
Feb 6, 2012 10:56 AM
dickie34
Oct 15, 2008 12:51 AM
BeachBumMike
Aug 15, 2007 07:06 PM
impalamonte
33
May 2, 2007 11:38 PM
Sparkplugs.com
Dec 7, 2006 10:45 PM
