PLEASE HELPHard Idle 2000 monte Carlo SS
Old Oct 12, 2010 | 07:41 AM
MonteLu's Avatar
Default PLEASE HELPHard Idle 2000 monte Carlo SS
I have a 2000 monnte carlo ss 3.8l. The other day I completely filled up my tank before going to work(15gal), then parked the car in the lot while I was at work. When I went to start the car up, it sputtered and seemed as if it wasn't going to cut on. It idles hard(shakes violently back and forth) but is completely fine when driving. When i'm at a complete stop, I have to put the car in neutral to reduce the shaking. I popped the hood and saw a hose by my air intake sucked in/squeezed in (normally its filled out), and I hear like a sucking sound. Not sure if that has anything to do with it. Does anyone know what I can do to fix it? PLEASE HELPPP
Old Oct 12, 2010 | 04:02 PM
ATP03SS's Avatar
you may just have a bad vaccume line? or sensor? try the IAC sensor or even the PCV valve. many opt for problems...
85v6
Oct 6, 2020 11:16 AM
bryan_p88
15
May 6, 2014 01:44 PM
MJClemm
Aug 12, 2013 08:02 AM
el402
Sep 24, 2011 10:58 PM
nlange
Oct 11, 2009 11:21 AM
