please help with 04 monte carlo ss supercharged
Old Jun 12, 2018 | 05:57 PM
scotts2003montecarloss's Avatar
Default please help with 04 monte carlo ss supercharged
Ok I have an 04 Monte Carlo SS Supercharged that is making me nuts. I have this bad leak in the passenger floorboard that I can't figure it out. I thought it was the heater core but the heat works really good and the leak that I am having isn't coolant it is just water. This doesn't happen when it rains. This happens when driving the car. I tried unclogging the a/c drain plug but didn't help. Like I said this issue isn't from the rain it is when car is driving or running. It seems like the leak is starting from the middle console under the a/c control unit.
Old Jun 12, 2018 | 06:19 PM
Jeffs02rwdSS's Avatar
I have ran into a similar situation 2 times in the past both were condensation in the heater box inside the car. It happened when someone prior to me putting in a heater core and.breaking the box installing. What happened was the water wouldn't make it to the drain at the bottom.If that's not the issue the only other thing it could be is water entering by the cabin air filter because the seal is not on properly. I understand that you said it's not rainwater but there's only so many possibilities. Good luck Scott
Christian Benito Francescon
Aug 9, 2019 03:23 AM
kretos
Jan 2, 2016 12:59 PM
shawnstoppable
Jul 12, 2011 07:46 AM
phillychad
Feb 3, 2011 09:04 AM
05SSMonteCarloSC
Feb 26, 2010 07:51 PM
