Opinion Needed: Plastic upper intake blew up!!
I did an engine swap in my 2000 monte ss 3800. She was running fine for about 5 months. I let her sit for a week because it was to cold for her to be running. I finally started her up and the upper intake blew up into a bunch of pieces. I had some flames from the intake hitting my fuel rail and snapping it and a spark from the electricals. I put the fire out with snow. My question is, if i was to replace the plastic and all then flush out my coolant and oil would she start up n be fine? Or what other steps should i take to make her run?
as long as it was just snow you dumped onto the engine (no rocks or dirt) and it wasnt a lot to flood the engine with water i think it should be ok. depends on if the fire damaged any wires etc though....
was a backfire that caused it most likely, i remember reading somewhere what causes this to happen but i cant remember now..... other members may know off the top of there head though.
Change the Fuel Pressure Regulator as you fix things back up. Those have a history when they fail allowing vapors to leak into the intake, when you start the car, it ignites the vapors and KaBoom!
It sure can. The reinforcement in the Dorman is just a 1/2" x 1" metal sleeve fit into the "Stovepipe" port where EGR gases are recirculated into the plenum. The rest of the UIM is all the same. The main culprit is the FP regulator, but Dorman's come with a new regulator as I recall.
