5th Gen ('95-'99): Passkey II Bypass
Hey, I bought a '95 Monte Carlo Z34 at some point last year, and I was wondering how I could bypass Passkey II for it. The car has a janky plunger button wired up (turn key to on, then depress the button and it fires up) and my dad believes it's because the previous owner removed the factory radio (triggering the anti-theft) and cut the wires to install an aftermarket radio. (why he did this, I have no clue, radio could've been busted *shrug* either way, there is definitely a better way to replace a radio than cutting the connectors off.) Removing the radio probably could've tripped the security system, deactivating the ignition switch, and thus, the plunger to bypass the ignition switch. To be clear, the car DOES start, and it has the original two keysets and one of the fobs. (it came with two, but the halves of the spare one wouldn't stay together, so it was thrown out) Key fob still works, so it likely still has the factory security system. We just wanna know whether the security system can be bypassed or not, so we can check and make sure it's not a bad ignition switch.
![Smile](https://montecarloforum.com/forum/images/icons/icon7.gif)
The ignition key has a little bump on it that once it is inserted in the ignition triggers the security device and makes it start. I have read that they can go bad once in awhile.
You can purchase new key fobs and reactivate them real easy.
I am thinking if you wanted the key to start the car you might need to put in a new switch and matching keys.
I have the service manuals for the 99 and they are great source of information. I will try to find something on this subject and get back to you on it.
Actually on the Gen 5 Monte Carlo the passlock only makes the radio inoperable(if stolen) if it had been set up to do that. I have had a 96 that my son used and I currently own a 99 if there was to be an issue with that He surely would have activated that problem.
S1knes
12-08-2013 07:44 PM
