Passenger Side Is Wet
Old Jun 17, 2024 | 06:51 AM
andrewml's Avatar
Default Passenger Side Is Wet
2003 SS 3.8L My Passenger side is wet. I feel like I've done everything at this point. I've poked around my AC drain, took off the boot and tried cleaning out the exit. I checked my sunroof drains and I've let all the water out of my passenger side door which I thought was the problem since there was a ton of water in there. But this morning my passenger side is still leaking. The water seems to be dripping from the lightbulb along the bottom of the glovebox area. Any ideas on my next course of action?
EDIT: It was the Air Cabin Filter problem!! My weather stripping beneath the cowl came loose and water was getting in there that way.
Old Jun 17, 2024 | 07:21 AM
Those sunroof drains can be a B! You need to snake a small wire in there then use compressed air, then run some water thru. I had to repeat that 2-3 times when mine got clogged.
Old Jun 17, 2024 | 07:53 AM
andrewml's Avatar
I'll be sure to try that out! Generally speaking, does the leak shown in my picture look about similar to when your sunroof drains got clogged?
Old Jun 17, 2024 | 11:08 AM
Is it possible its the cabin filter issue:
https://montecarloforum.com/forum/fw...lem-fix-26663/
DonVincenzo
Oct 5, 2025 01:48 PM
ThunderSlug
Nov 6, 2022 04:53 PM
Jason B
Feb 21, 2019 11:05 PM
cjd82675
Nov 12, 2018 04:42 PM
MonteSSS
Jan 30, 2012 08:21 AM
