Parts from 95 into 97?????
Old Dec 4, 2010 | 05:08 PM
jshladwig's Avatar
Default Parts from 95 into 97?????
I was just curious if it is possible to take parts from a 95 monte carlo z34 3.4L into a 97 z34 .34L? as far as engine parts,timing belt and pulley,etc?
Old Dec 4, 2010 | 05:44 PM
mrl390's Avatar
Not all engine parts are interchangeable but I believe the timing belt, pulleys and tensioner should all transfer over.
Old Dec 4, 2010 | 06:39 PM
gothkid's Avatar
If they look like the same motor i dont c any harm, the 3.4 didnt change much in the time period.
Old Dec 4, 2010 | 06:49 PM
mrl390's Avatar
Everything from the heads up is different between the 95 and the 96/97 motors. The timing belt setup and all the accessories should be the same.
Old Dec 4, 2010 | 07:14 PM
jshladwig's Avatar
Thanks...some guy is selling a 97 z34 with lambo doors and he said all it needs is the timing belt and the pulley but something is fishy cause all he's asking is $650.00?????????? The body is clean.
Old Dec 4, 2010 | 07:35 PM
mrl390's Avatar
Be weary because if the timing belt broke, there is a very good chance that one or more of the valves are bent from hitting the piston. Anyone who neglected their LQ1 long enough for the timing belt to break probably has used and abused that car way too much. I would only buy it for parts, not with hopes of making that car a runner, unless you are willing to have the heads re-done and possibly replace the pistons or even swap another motor in.
Old Dec 4, 2010 | 07:40 PM
jshladwig's Avatar
Thats exactly what i was thinking, I already have a nice 95 z34 I just need to replace my cat or clean it out since it doesnt have to pass the emissions but I probably would feel a lil guilty about that so Im just going to pass up that 97 MC. Thanx for the info and helping me decide!
Old Dec 5, 2010 | 12:01 PM
mrl390's Avatar
If it were a 96 not a 97, I would say buy it anyway and swap the upper and lower intake manifolds, fuel rails and throttle body and just use the 96 computer. Since its a 97, the computer wont control your trans so it wouldnt be worth it.
l67ss
16
Jan 31, 2014 11:20 AM
MJClemm
Mar 16, 2012 10:49 AM
Oct 21, 2010 10:43 AM
4reyes
Dec 2, 2008 07:30 PM
