p0481 code help
Old Dec 22, 2013 | 07:40 PM
mudmnster's Avatar
Default p0481 code help
Everybody,
I have a 2002 Monte Carlo 3.4 engine. I am getting a p0481 code. The fans work when I put a jumper to them. I have changed the 3 Relays, when I put a test light to the fuse box it seems to have power. The pigtails that go to the fans seem not to get any power. I took off the fuse boxes from the engine compartment and checked the wires to see if they are all snug in the fuse box and they are. I checked all the rest of the fuses under the hood and both driver and passenger fuse boxes.
This is my first Monte Carlo and my first post.
I have a 2001 Malibu that I've had to do much work on. I need the code off and the fans working so I can get the car emissions and registered.
Thanks for any input
Brian
Old Dec 22, 2013 | 08:34 PM
JC Colon's Avatar
Check the wiring in the main harness. You may have a bad wire or connection into the computer. The Haynes manual has an accurate wiring diagram for the Monte!
Old Dec 23, 2013 | 11:20 PM
mudmnster's Avatar
Thanks I will check that next. My local Chevy dealer has been no help whatsoever.
Brian
Old Dec 29, 2013 | 05:21 PM
mudmnster's Avatar
ok, so checked all the wires that I could anyway. Pulled the fuse boxes off the fender well. Didn't find anything that seemed disconnected or damaged. pushed everything in tight.
So, my P0481 is gone and now replace with p0118. I replaced the coolant temperature sensor and the low coolant sensor. its also now blowing fuses for the fans. I'm at a total loss now. thanks for any help anyone can give.
Brian
Old Dec 29, 2013 | 06:54 PM
JC Colon's Avatar
I'm not sure. I Hope one of the members with more electrical knowledge on this car will chime in.
When you jumpered your fans, the fuses didn't blow, now they do. What has changed since then? Also, after the parts you replace, your CEL code changed. That Also points to the work just done.
This is the way I would hunt down the problem.
Big Mike
Aug 14, 2009 01:18 PM
Steven73
May 31, 2009 07:22 PM
BlownCenturion
May 7, 2008 06:29 PM
Suppoko
Apr 24, 2008 06:30 AM
HyperFox
Jul 31, 2007 05:40 PM
