P0171 Error Code
Old Aug 31, 2013 | 01:44 PM
lezloh's Avatar
Default P0171 Error Code
2002
3.4 LS
185,000 miles, engine replaced with rebuilt engine at 140,000
I know the code is a too lean code. I have also isolated the source of the leak, but I am not sure what the name of the line is, so I can go get a new one.
Would someone be able to tell me the name of the line in the attached picture? Also, it looks like the line runs from the front of the engine to a box in the on the side of the engine. The leak is in the middle where it appears to push into the engine. There is where it looks like it has split. It looks like it can be replaced without much work. Is this true?
File Type: jpg
Old Aug 31, 2013 | 01:53 PM
lezloh's Avatar
Is it the pcv valve line?
Old Aug 31, 2013 | 01:57 PM
Hi that is exactly what my thoughts were, it's the PCV valve. You should be able to pull it out and it will have a rattle to it as the vlave inside moves when you shake it. I clean mine out with carbureator cleaner and reinstall it. So is the line broken?
Old Aug 31, 2013 | 02:01 PM
lezloh's Avatar
Default More Information
This picture has the line highlighted and the green arrow is where the leak is located. It looks straight forward to replace.
File Type: jpg
Old Aug 31, 2013 | 02:55 PM
That is a PCV line. And the item with the arrow is commonly/generically called a "grommet". To my knowledge, that piece is a dealer only item.
You might be able to fabricate something or get one from a junk yard (pending it's in good shape). Could mess with some gasket/rtv sealant.
How bade it that piece??
Old Aug 31, 2013 | 03:22 PM
lezloh's Avatar
Default Fixed
O'Reiley's the grommet. I replaced and it seems to be working now. Only time will tell.
Old Sep 1, 2013 | 07:08 AM
03SSLE's Avatar
It is not recommended to apply any type of gasket or silicone sealer to a vacuum port. It can/will get sucked into the engine and could damage it.
Old Sep 1, 2013 | 11:00 AM
lezloh's Avatar
I just stuck the new grommet in, no sealant.
Old Sep 1, 2013 | 12:24 PM
I completely agree (it some with risk if you are not careful). By and far, RTV or some sealant is NOT my first choice for the application For that spot on the car if it were to be used, should be sparingly. Or for that piece, you could be possibly to use it to "reform" the piece, dry and then reconnect (so it would not plug anything).
Plus side, the OP found a new grommet at the parts store, best answer of all
Skialdi
Jul 29, 2018 06:54 PM
matt210
Jun 11, 2012 06:08 AM
1FasImp
Aug 30, 2011 10:51 AM
Sparky-88
Jul 12, 2011 03:28 PM
