Code P0141
Old Jun 12, 2009 | 05:41 AM
StretchMC's Avatar
Default Code P0141
well like the subject suggests i have a P0141 code popping up. I know what it technically means but when i search for reasons/answers/fixes all i get it the same technical answer that my code reader gives me. any suggestions on where i should look or how to fix would be great. thanks in advance...
Old Jun 12, 2009 | 05:48 AM
Welcome to the MCF Family
Sorry 2 read that you are gett'in codes.
What year/engine do you have ?
How Many miles ?
Check back later to see what our expert tech member's post
and check out the below link.
Good Luck
http://www.obd-codes.com/p0141
Old Jun 14, 2009 | 02:54 PM
StretchMC's Avatar
sorry i should have given more of a back story. i have 2000 ls that ive had for six years. ive done all the work on it myself including the dreaded LIM leak and head gaskets. the car has 123,*** on it. the only mods that i have are zzp downpipes with cats that i put on only a few months ago (thinking thats what the problems are coming from/ started around) borla cat back and self made short ram intake.
Old Jun 15, 2009 | 10:24 PM
nemesis's Avatar
2009 Monte Of The Year
that's prob how the code pop up, when removing the old cat and installing the dp. have you try to remove the code?
Old Jun 16, 2009 | 05:03 AM
StretchMC's Avatar
yeah ive tried removing the code but it pops up quickly after
Old Jun 16, 2009 | 05:46 AM
Keep checking back to your thread question & hopefully one
of our expert tech's will post their opinion/solution.
Below are links pertaining to your code problem.
Good Luck, from `Space
Old Jun 16, 2009 | 09:07 AM
are you removing the code or just clearing it?
Removing means to delete the code from your PCM, clearing it just erases it until the next time your car finds that problem.
It's common that a downpipe + high-flow cat will set off a code, because your PCM is used to the restrictive stock pipe, so now it thinks this new one is broken.
To fix it without a tune you would need to buy an O2 simulator that replaces the rear O2 sensor.
Old Jun 18, 2009 | 09:21 PM
StretchMC's Avatar
i would need the simulator even though the new O2 sensor is hooked up and in? also how would i go about deleting the code from the PCM because youre correct when you say that i have been just clearing it
Old Jun 19, 2009 | 08:45 AM
To fully delete it, you would need tuning software, or a canned PCM from a place that does those box tunes, like zzp with the delete already done.
can2tx
Nov 18, 2013 02:20 PM
Leprechaun93
14
Mar 30, 2013 08:53 PM
dirty mech
May 2, 2010 02:49 PM
chorales
Jul 24, 2005 05:33 PM
king2805
Jul 14, 2005 10:34 AM
