p0137 code - replace 02 sensor? Which one?
Old Oct 14, 2015 | 08:29 AM
Mcvfd12's Avatar
Default p0137 code - replace 02 sensor? Which one?
Hi guys, i've fixed about all the issues with my new to me 2001 monte carlo with the exception of the p0137 code that continues to return. From what i've read, it's the rear 02 sensor on the bank 1?
Amazon.com: ACDelco AFS109 GM Original Equipment Heated Oxygen Sensor: Automotive Amazon.com: ACDelco AFS109 GM Original Equipment Heated Oxygen Sensor: Automotive
Will this 02 sensor do the trick? Also, I need to replace the one that goes in the rear manifold, correct?
File Type: jpg
Old Oct 14, 2015 | 04:49 PM
I have not looked up the code, but if it's the rear O2 sensor, that is the one behind the cat (and it will be contained in what is known as the u-bend). The rear is also known as the downstream.
The front O2 sensor is is on the rear exhaust manifold, also known as the upstream.
These cars only have the 2 O2 sensors.
Old Oct 14, 2015 | 06:51 PM
Mcvfd12's Avatar
I guess I haven't seen one behind the cat, maybe I wasn't looking hard enough, but I didn't see one there.
Old Oct 14, 2015 | 09:59 PM
It's there and is seen standing straight up, right after the cat.
File Type: jpg
Old Oct 20, 2015 | 06:00 AM
Mcvfd12's Avatar
Replaced the downstream 02 sensor and this took care of my problem. Thanks!
