Starter went bad (I believe)
Old Oct 18, 2015 | 09:05 AM
AlexRose's Avatar
Unhappy Starter went bad (I believe)
So the other day I was working on my Monte and I noticed my radio would not come on so I pulled apart my dash and saw the fuse for the one wire was blown, and was about to fix it when I was asked to move my car out the driveway cause a family member had to move their car. Well right when I went to turn the key, nothing happened. No clicks,no turnover. So I figured maybe its battery, tried jumping it, still nothing so I realized it wasn't dead at all. So now I'm assuming it is my starter. Which blows because they're not cheap. So now I'm going to pull a part today to yank one off another monte. Hoping this fixes the problem. Is there anything else that it cold be or should know? I did see a video of this guy taking it apart and cleaning it, saying it just had bad connection. But I looked and I don't think that, that's the case at all. Soooooo just gonna see if I can fix it with another starter, if not I'm gonna hot wire it until I get money to fix whats wrong.
Old Oct 18, 2015 | 10:57 AM
Did you move and possibly short out any wires when you pulled apart the dash assembly? Seems odd one minute your starter works, you pull apart the dash, find a burnt wire and now your starter don't work. Wonder if you tripped the anti-theft mode in your security system?
Old Oct 18, 2015 | 02:41 PM
AlexRose's Avatar
Not that I know of, think my solenoid is bad
Old Oct 18, 2015 | 03:26 PM
I just replied to a PM, this says a little more about what's going on. No clicking, no cranking. Do you have an active security message on the cluster? If I recall, when the car is in theft lock mode, it will not crank the starter.
If you have anything after market (like a remote start), depending how it was wired, some people do "hack" jobs and taking apart the dash may have disturbed a fragile wiring job for example.
Don't rule out a dead battery. If the battery has failed cells and hit end of life, usually you can get the starter to "click", but not all the time. And jumping the car is not always enough.
The local part stores can all bench test a battery and starter.
I would begin with ensuring the battery is "healthy" (such as a full charge on it).
Old Oct 19, 2015 | 09:26 PM
AlexRose's Avatar
I don't have the security thing that shows in the message center anymore just shows my battery emblem in it, car still doesn't start, just makes one click and that's it. Idk what else it could be other than my starter being bad which I hope it isn't, put another ignition switch in it and it didn't help
Old Oct 19, 2015 | 10:10 PM
AlexRose's Avatar
Default I want to rip my beard off
I've tried just about everything, jump starting it. And no I didn't do it the ghetto way cutting the wires in my wiring harness, just ran a wire to both pink wire, and stripped a space of rubber in the middle and used a mini jumper cable to touch the spot on the brown and it still did the click like how it did with the key in it
Old Oct 19, 2015 | 10:14 PM
AlexRose's Avatar
Also I noticed that when I try to start it my miles don't show up just the gears light up, now I don't know if im being paranoid and it always does that until the car is fully in or if that's a hint to what is wrong
Old Oct 20, 2015 | 06:32 AM
Sometimes a part in the cluster fails that causes the mileage not to display (I have not had to replace i but I have read of others that have, just requires being handy with a soldering iron and knowing the component to swap).
When you swapped the ignition switch, did you also keep the original lock cylinder? The lock cylinder has the passlock chip on it, if you did not, you are going to add to the problem by needing a security relearn.
Honestly, based on what you said, I would pull the battery and take it to be tested.
Old Oct 20, 2015 | 08:16 AM
AlexRose's Avatar
I actually have two lock cylinder, the original which is in it and the one from the new switch which I have a key to
