P 0300 Code
Old Mar 26, 2008 | 09:58 AM
ericking22556's Avatar
Default P 0300 Code
Got a P 0300 code, dealer isolated it to the No. 1 injector. Wants T&M to fix it. 98000mi. '02 SS. Any help?
Eric
Old Mar 26, 2008 | 12:59 PM
rysZ34's Avatar
Default RE: P 0300 Code
Put some seafoam in your gas tank run it through see if that helps it. It's cheaper than an injector and labor. )
Old Mar 26, 2008 | 04:56 PM
bowtietech's Avatar
What is seafoam??
Old Mar 26, 2008 | 05:15 PM
RickCoMatic's Avatar
SeaFoam is a Brand of Solvent. Witch Doctors say it can do everything including making you teeth white; again! Gas line and Fuel Injector Cleaner is the same stuff in a different can and costs about the same.
SeaFoam is supposed to dissolve crud and make your engine run like new, again. Since you can get a can for, like ... 10-Bucks ... pouring a can in the gas tank MIGHT clear-out the problem with the injector.
However ... If you haven't replaced the Fuel Filter lately ... and there is micro-particulate getting through the element ... it might be a wise choice to replace the Fuel Filter BEFORE adding the SeaFoam to your Tank ... because the SeaFoam is going to dissolve what ever is in the Filter and might allow some micro-crap to get up the line and foul some of your other injectors; too.
Old Mar 26, 2008 | 06:03 PM
rysZ34's Avatar
Good call, Rick. Fuel filter needs to be replaced too....I knew I forgot something. lol.
yfz450man
Jul 24, 2011 02:21 AM
Pete Nyce
Mar 15, 2011 03:09 PM
cj702
Aug 28, 2005 12:50 PM
chorales
Jul 24, 2005 05:33 PM
king2805
Jul 14, 2005 10:34 AM
