5th Gen ('95-'99): oil and air filter cabin
Old Aug 22, 2012 | 03:00 PM
christophe mc france's Avatar
Arrow oil and air filter cabin
3100CC engine , how many oil liters must i need if i change the oil, and do you know if there s an air filter cabin and where is
Old Aug 22, 2012 | 04:21 PM
Robbase's Avatar
5qts. but to be safe put 4qts., turn on your engine for about 5 seconds,then turn off.check the engine dip stick, if u need more just add little more . until measurements are right. the cabin filters are sometimes located above the fire wall,where the wipers are .you have to remove wiper arms and plastic cover, on chevys. good luck.
Old Aug 23, 2012 | 07:00 PM
zipper's Avatar
5th gen Monte's don't have cabin filters.
Old Aug 23, 2012 | 09:06 PM
Mike 00LS's Avatar
In my LA1 (3400) I do 4.5 qts and then increase from there if needed. It's always better to run a shy low than overfilled.
Old Aug 25, 2012 | 02:12 PM
zzapultimate's Avatar
4.5 Quarts is what I use. And zipper is correct in there is no cabin air filter.
Laserblue06ss
Oct 25, 2023 08:51 AM
fastback4
Jun 14, 2008 06:03 PM
God_Bot
Mar 14, 2008 07:24 PM
RickCoMatic
Dec 16, 2007 07:15 PM
03SSdriver
Oct 5, 2005 08:13 PM
