5th Gen ('95-'99): oil and air filter cabin
5qts. but to be safe put 4qts., turn on your engine for about 5 seconds,then turn off.check the engine dip stick, if u need more just add little more . until measurements are right. the cabin filters are sometimes located above the fire wall,where the wipers are .you have to remove wiper arms and plastic cover, on chevys. good luck.
