7th Gen ('06-'07): Oil
Old Mar 6, 2021 | 03:59 PM
DopeSquid's Avatar
Default Oil
I have the 3.5l v6 I've done two oil changes so far and both times the oil filter has been covered in oil dripping off I don't know where from any ideas?
Old Mar 7, 2021 | 02:57 PM
I had the same issue back when I used to have a 08 Impala with a 3.5.
Mine ended up being the gasket for the oil filter adapter that goes between the adapter and the engine block. The oil would leak out of the gasket, run down the lower edge of the adapter, onto the filter, then onto the ground. So the oil filter had oil residue all over at each oil change.
A bit of a pain to change as there's not much room to work with in there, but it is doable in the car.
Skatulaki
Apr 3, 2019 08:56 PM
monte07
May 7, 2013 10:33 AM
LENNYF666
Nov 3, 2009 09:40 AM
Nightmare!
Jan 31, 2009 11:03 PM
hot95mcz34
Jul 1, 2008 10:10 AM
