Odometer and overhead info go dim
Old Jul 6, 2018 | 02:12 PM
200dollarmonte's Avatar
Default Odometer and overhead info go dim
So I just recently acquired a 2005 monte. my question is my odometer and overhead info goes dim after I start vehicle. when I first turn on key its bright then goes dim seconds later. I can still see them but feel its not right. is this the indication of the dimmer switch bad?
I will add that I did an led swap. If this has any relation I cant verify. the leds don't dim so I assumed that was normal
thanks
Old Jul 7, 2018 | 03:58 PM
Check maybe the sensor is dirty.. Up on the dash board, little nub thing..
Should be bright in the day and darker at night..
Old Jul 8, 2018 | 09:37 PM
HurricaneSSman's Avatar
It sounds like a bad sensor. It thinks it's dark outside when it isn't.
Old Jul 11, 2018 | 12:10 PM
thanks guys...I shoulda known this issue...lol. the dash had been painted and the sensor was covered. duh...lol
AwesomeSS
Jun 8, 2015 10:58 PM
cellman26
Jan 19, 2014 07:36 AM
Denzell Rodgers
Sep 16, 2013 08:13 AM
MonteGuy
Jan 21, 2011 09:04 PM
phoenixdude24
Jun 4, 2008 06:54 PM
