Odometer and overhead info go dim
So I just recently acquired a 2005 monte. my question is my odometer and overhead info goes dim after I start vehicle. when I first turn on key its bright then goes dim seconds later. I can still see them but feel its not right. is this the indication of the dimmer switch bad?
I will add that I did an led swap. If this has any relation I cant verify. the leds don't dim so I assumed that was normal thanks |
Check maybe the sensor is dirty.. Up on the dash board, little nub thing..
Should be bright in the day and darker at night.. |
It sounds like a bad sensor. It thinks it's dark outside when it isn't.
thanks guys...I shoulda known this issue...lol. the dash had been painted and the sensor was covered. duh...lol
