o2 sensors the same?
Old Mar 1, 2014 | 05:40 PM
2002 SS's Avatar
Default o2 sensors the same?
Sorry for blowing up the forum with questions, but Im looking to replace the o2 sensor. Are there differences between downstream and upstream sensors, or are they both the same/interchangable? I see some for sale online, and they state they are for both, but Im unsure. thnks!!!
Old Mar 1, 2014 | 06:32 PM
Yes the same sensors for up and down stream.
Old Mar 1, 2014 | 07:02 PM
2002 SS's Avatar
Upon further review, it looks like the plugs are different.. one looks like a male plug connection and the other female?
Old Mar 2, 2014 | 11:37 AM
Whatever you do...
DO NOT BY BOSCH O2'S.. unless you want constant problems with them!
Do not buy them from ebay also...
Purchase them at your local trusted auto parts...
Only buy AC Delco replacements!
Old Mar 2, 2014 | 11:48 AM
2002 SS's Avatar
Originally Posted by STUMPMI
Whatever you do...
Tkz for the tip, may I ask why?
Old Mar 2, 2014 | 12:24 PM
Because they have a high failure rate.... there JUNK!!!!
So anything you do to your Monte Carlo...
Always replace any electrical parts with OEM original replacement parts!
Old Mar 2, 2014 | 01:21 PM
2002 SS's Avatar
Will do, but before I order, I noticed a plug difference with the upstream vs downstream. Looks like the downstream ( one i need) is a male connection, whereas the upstream is female, can anyone confirm this?
Old Mar 2, 2014 | 07:24 PM
owens91's Avatar
i agree with mr, dave. i got an upstream o2 when i first got ma car at 89k, couple weeks ago the thing made my whole car act real weird. i was mainly getting codes for the o2.but went on rockauto.com and got a ac delco replacement and all the problems went away
Old Mar 2, 2014 | 08:00 PM
03SSLE's Avatar
I could be mistaken, but I think the front and rear sensors are different - or at least AC Delco shows different part numbers for them:
Front: ACDelco 213-2873
Rear: ACDelco 213-1331
You may want to double check when you're at Rock Auto or wherever you decide to go.
BeachBumMike
Aug 16, 2007 04:53 PM
fastback4
Dec 11, 2006 10:04 AM
Greeny
Oct 30, 2006 11:50 PM
GrandPaDave
FWD Tech Guides '95-'07
Sep 17, 2006 02:38 AM
monte84
Jul 12, 2006 12:18 AM
