O2 Sensor fuses?
Old Feb 8, 2012 | 06:01 PM
myronprescott's Avatar
Default O2 Sensor fuses?
I just replaced my O2 sensors about a week ago & my check engine light is still on. I was told that it may be fuses connected with the sensors that may be faulty but I can't find any fuses that go with them am I missing something or am I being told wrong?
Old Feb 8, 2012 | 09:11 PM
Jomao_o's Avatar
You have to erase the codes.
Autozone USED to do it, but after lawsuits it no longer offers the service of deleting the code. You may have to go to a dealership or find someone with a OBDII reader.
Old Feb 9, 2012 | 08:25 AM
What year is your car? Did you put the correct o2 sensor in? In the newer cars they have a heating unit on them.
Also disconnect your battery for an hour and that should clear the codes.
Old Feb 10, 2012 | 09:26 AM
07 & is the heating unit part of the 02 sensor because that was the code that popped up
Old Feb 10, 2012 | 10:42 AM
Yes it is built into those o2 sensors. Did you buy a non-heated one? Or maybe the wiring is bad and not the sensor?
Old Feb 14, 2012 | 12:55 AM
Bosch 15155 - Oxygen Sensor | O'Reilly Auto Parts
Bosch 15902 - Oxygen Sensor | O'Reilly Auto Parts
These were the sensors that I bought to replace, are these not correct?
Old Feb 14, 2012 | 06:19 AM
monte07's Avatar
what i am aware of there are two types of 02 sensors for the front heated type and the non heated type. there should have a list and the description of the two types. when you replaced the first one did you make sure the hole as well as the conection to the sensor was clean? i had to get the code removed from the ecu what i mean i had to take it to the dealer to have them clear it because no matter how many times i cleared it. the check engine o2 sensor error messege came back. the dealer checked the cat they said it is fine but it needed to be told that the sensor was changed
Old Feb 14, 2012 | 08:31 AM
The problem might be the fact that they are Bosch.
I know W-Bodies can be picky when it comes to O2 sensors. Bosch is on the list of sometimes doesn't work for us.
Old Feb 22, 2012 | 11:21 PM
I went to a mechanic today & he said based on my codes its probably my fuses. I checked all my fuses & they're fine so I'm lost? Also I noticed I burning type smell coming from the upstream o2 sensor area when i cut the engine off. If anybody has any clue what's going on, I need the help.
Old Feb 24, 2012 | 06:56 PM
Found out my problem finally, it turns out my ECM CPU needs a software update, $100 from the dealership
plokm24
Feb 13, 2012 05:16 PM
02monte3.4LS
Jun 17, 2011 04:09 PM
novagenesis300
13
Dec 1, 2010 07:18 AM
nitehwk10
Jul 23, 2008 05:36 PM
rcohen
Feb 12, 2007 08:49 PM
