Normal Temp in 04 Monte with 3400
I was wondering if someone could tell me the range for normal temperature on my temp gauge in my 04 Monte Carlo 3.4 V6. When it's in idle, like when I go through the drive thru of a restaurant, the gauge will be pushing a little over half and go back down and repeat. Can someone tell me if this is normal? I feel like my car is overheating when this happens
Little over half is fine. Halfway SHOULD be around 195 which is the thermo setting to open.
If you haven't done a coolant flush in the past 5 years, I would get it done as proper maintenance of the system, and peace of mind.
Do check the coolant level in the radiator when it's cold, fill it all the way up to the cap if needed that'll help reduce the fluctuation. Also that's a sign that the water pump isn't at 100% operating level. My 03 Monte 3400 spent 99% of its life with the needle just below the halfway mark and it didn't fluctuate like yours.
Yes it does have original engine & tranny..... and I am at 223,6xx now. I also have my milage noted in my signature below "223K". I am the 2nd owner & purchased it in 2006 with 34,000 miles
Dang that is awesome. I hope mine lasts that long! I just hit 119k a couple of days ago.
