Normal Temp in 04 Monte with 3400
Old Feb 2, 2016 | 02:23 PM
AHart87's Avatar
Default Normal Temp in 04 Monte with 3400
I was wondering if someone could tell me the range for normal temperature on my temp gauge in my 04 Monte Carlo 3.4 V6. When it's in idle, like when I go through the drive thru of a restaurant, the gauge will be pushing a little over half and go back down and repeat. Can someone tell me if this is normal? I feel like my car is overheating when this happens
Old Feb 2, 2016 | 02:40 PM
Little over half is fine. Halfway SHOULD be around 195 which is the thermo setting to open.
If you haven't done a coolant flush in the past 5 years, I would get it done as proper maintenance of the system, and peace of mind.
Old Feb 2, 2016 | 04:04 PM
jim1405's Avatar
x2 My 2001 3.4 behaves the same way
Old Feb 2, 2016 | 07:46 PM
Habbibie's Avatar
Do check the coolant level in the radiator when it's cold, fill it all the way up to the cap if needed that'll help reduce the fluctuation. Also that's a sign that the water pump isn't at 100% operating level. My 03 Monte 3400 spent 99% of its life with the needle just below the halfway mark and it didn't fluctuate like yours.
Old Feb 3, 2016 | 12:10 AM
KCFITZ78's Avatar
mine always peaks right under 200 deg F at idle.......
File Type: jpg
Old Feb 4, 2016 | 02:19 PM
AHart87's Avatar
Good to know I'm not the only one. Recently I drained some antifreeze out and put more in. I filled the radiator and filled the reservoir up to the line. I was afraid that the engine was overheating. Thanks!
Old Feb 4, 2016 | 02:24 PM
AHart87's Avatar
Does your Monte have the original engine/tranny? I'm just curious because of the mileage haha
Old Feb 6, 2016 | 12:51 AM
KCFITZ78's Avatar
Yes it does have original engine & tranny..... and I am at 223,6xx now. I also have my milage noted in my signature below "223K". I am the 2nd owner & purchased it in 2006 with 34,000 miles
Old Feb 10, 2016 | 02:56 PM
AHart87's Avatar
Dang that is awesome. I hope mine lasts that long! I just hit 119k a couple of days ago.
