Noise when moving in reverse
Old 01-31-2008 | 09:49 AM
PsuBrock's Avatar
Default Noise when moving in reverse
Okay, hopefullysomeone elsehas heard this noise and can tell me what it is.
I'm talking about the suedo grinding noise after you've put the car in reverse and let off the brake. It only happens when the car has sat and it is the first time you've driven it that day. My new to me monte does it, my fiance's old GP with the same 3.1 did it, and my mom's Montana with the 3400 does it too. They all make the same distintive noise. I know it doesn't mean anything is wrong (the van is a 98 she's had since 2000 and did it from day one) but I was just wondering if anyone knew what actually causes that noise.
Old 02-02-2008 | 08:07 PM
RocknSS04's Avatar
Default RE: Noise when moving in reverse
Sounds like a brake caliper problem to me. Maybe a stone, salt, or some other corrosion in the calipers, not letting it release properly
Old 02-04-2008 | 03:42 PM
PsuBrock's Avatar
Could be, but that quickly turned to the least of my worries now that I have to replace my intake gaskets [:@]
Old 02-09-2008 | 12:05 PM
mikes03ss's Avatar
if your going to do the lower intake spend the extra money and go with fel pro problem solver gaskit kit it will save u from doing it in the future again
iMSeRiOuS
11-25-2012 10:51 PM
MAMONTE
09-22-2009 07:01 PM
monte carlo 3831
05-26-2009 11:24 PM
jjjustin17
05-26-2009 09:39 PM
