No heater when first starting or idling
Old Mar 2, 2013 | 03:39 PM
hacknfrack's Avatar
Default No heater when first starting or idling
2007 Monte Carlo LT
I have a problem that could be many things, but it's been going on for a while. When I first start the car up and the heat turned on, there is no heat for about 5 minutes of driving. If idling, there will never be heat. If idling from driving, the heat will turn off and start blowing cold air.
At the same time, my rear defroster does not work at all.
Also, when the driver's side temperature is turned all the way to cold, there is a constant clicking for about 30-60 seconds.
Is there anyway to replace the climate control unit in the dash?
Any other suggestions?
Thanks.
Old Mar 2, 2013 | 03:59 PM
Dougkb45's Avatar
Sounds like your low on antifreeze, Probably a bad water pump (leaky). If you do a search here you will find some info concerning the ticking noise
Doug
Old Mar 2, 2013 | 04:30 PM
Barovelli's Avatar
The clicking thing sounds like a air divert door not opening. Might check this post
https://montecarloforum.com/forum/ge...er-side-18429/
Old Mar 2, 2013 | 05:15 PM
aussiek2000's Avatar
Originally Posted by hacknfrack
2007 Monte Carlo LT
Low on coolant. 3.5/3.9 100% failure rate of coolant crossover pipe gaskets.
Purple wire in right kick panel is melted at connector. GM repair is to bypass connector by cutting out burnt section of wire.
temp door actuator is broken
Thanks.
My answers in bold. Fairly common problems.
Enzo354
17
Feb 9, 2011 08:59 PM
bwill987
Feb 26, 2010 08:27 PM
mattilus2121
Feb 26, 2009 02:33 PM
maclawa
Mar 18, 2006 03:32 PM
