6th Gen ('00-'05): no fan for heat or ac
Old Nov 16, 2014 | 02:56 PM
supersexy04's Avatar
Default no fan for heat or ac
I just found this site it looks wonderful. shortly after I make this post I'll post in the new members section, I was just too excited to ask my question.
I have an 04 Monte Carlo SS non Supercharged, after replacing the plugs and wires I now have no fan that blows the heat or the air conditioning in the cabin of the car. is it somehow possible that my friend accidentally unplugged a wire that is necessary for this motor to work? the only thing he did under the hood of the car was replaced the plugs and wires.
If this isn't a possibility what could be the reason why It quit working? it was working excellent before.
I'm looking forward to hearing your guyses suggestions, hopefully they're from someone who knows a little bit more about the car than me cuz I don't know much at all, but I am learning.
Old Nov 16, 2014 | 07:26 PM
vincenti's Avatar
The blower motor that makes the A/C and heater blow isn't all that close to the plugs or wires, but it wouldn't hurt to check it. If everything is OK there next thing to do would be to check the fuse.
Old Nov 16, 2014 | 07:39 PM
I would dbl check all the fuses...
Under the hood and inside the car as well...
If you find all the fuses are good...
It could be the fan resistor.. Which is located and attached to the fan motor
This is what it looks like...
Its quite possible its coincidence that it quit after the tuneup...
Its a common occurrence.. and fairly simple to replace..
Old Nov 17, 2014 | 05:23 PM
thank you for reminding me about the fuses, I didn't even think to check them but they're all good.
tomorrow I will attempt to gain access to the resonator and blower motor. I'll check with the electrical meter if the blower motor is getting power. if the blower motor is not getting power then it would be the blower motor that is bad I'm assuming. if the blower motor is not getting power then I will check to make sure the resonator is getting power. but I'm a little lost at this point if the resonator isn't getting any power where would I look next?
hopefully its something simple just like the resonator.
thank you for all the help so far
Old Nov 18, 2014 | 05:58 PM
Aerocoupe86's Avatar
Monte Of The Month -- November 2016
by chance the curise light on the cluster isnt lit up is it? and/or the over head info disply inop?
Old Nov 19, 2014 | 09:12 PM
I fixed it!
it turned out that it was just the blower motor
I think it is worth noting that in order to fix this you have to be in some very very awkward positions.
Old Nov 20, 2014 | 07:23 AM
Good to know it was just a blower motor..
Old Nov 20, 2014 | 02:01 PM
Soundwave22's Avatar
How did you fix it???? I just replaced my resistor and I still can't get any air to blow out.
Old Nov 20, 2014 | 04:29 PM
owens91's Avatar
if the fuses are good and resistor is new more than likely its the blower, maybe someone did a write up
gmartinez93
May 11, 2015 10:45 PM
NYGiantsfan
Aug 15, 2013 07:43 PM
jhbasse
Jan 15, 2013 06:39 PM
ownedbypugs
Jul 31, 2010 01:16 PM
mcarloss04
Nov 21, 2005 11:38 AM
